AVR300 video settings question
Discussion in 'Arcam Owners' Forum' started by seanb724, May 18, 2005.
  1. seanb724
    seanb724
    I have an airport express connected to my AVR300 as the AV. In the advanced menu, I am not able to assign "SAT" to this on the HQ Video input AV as SAT is already assigned to HQ Video SAT. However, if I go into the main menu (just briefly press menu instead of holding it down for a while to go to set-up), I can change it there to get my SAT video when the AV is playing.
    Anyway to make that a permanent change?
    Thanks,
    Sean
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Not on the AV input because it is a video input and is expected to have independant video. If you want to do this you need to use one of the audio inputs CD or Tape then in the advanced video settings menu select the video source to be associated with e.g tape to be DVD. This will then pick up the fact that the DVD input is set to HQ and give you DVD video when you select the Tape input.
    Regards,
    Andrew
