AVR300 Video settings - help!
F
foxfan
I've just linked my iPod up to my AVR300 through the AV coax input and wanted to set it up so i could watch / surf satelite TV at the same time as listening, (my sat box is switched through the AVR) as I do with the CD setting.
Going into the 'Setup Menu Index', under 'Advanced - 2. Video', I cant select SAT video through AV input (AV is in a different menu under HQ video settings).
I may be just overlooking something, any good ideas out there as to how to fix this? (Note: I can't use the DVD-A input as this is in use).
Appreciate any help from you learned-lot....
