AVR300 sound cut-out problem
Discussion in 'Arcam Owners' Forum' started by GarethL, Jan 6, 2005.
  1. GarethL
    GarethL
    I have a AVR300 with a DVD player connected via digital optical and a Freeview box (old without digital output) connected via analogue connection with direct selected.
    When I switch from watching a DVD to watching the Freeview box (Sat) I get no sound. I have to switch to another source then back to Freeview (Sat) to get any sound.
    Is this a known fault ? Can it be fixed with a software update ?
    The software version of my AVR300 is 2.90, DSP 1.12.
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    I occasionally get the same problem when switching to the CD input of my AVR300 but not all the time.
    John
  3. Remboy
    Remboy
    I have experienced the same problem with my AVR300 which apears to be related to the use of the stereo direct facility. I have early AVR300 with original software and thought the later software versions had corrected this but haven't bothered to update.
    I found a way to avoid the problem (if what you're experiencing is the same thing) - switch the input on the AVR300 (or switch the power to the AVR300 off) BEFORE switching off the power to the source currently selected.
    Hope this helps.
  4. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Used to have this issue (no sound, only some strange swishing sound coming out of DIRECT to DD) but I haven't heard it since the one-before-the-latest upgrade.
  5. GarethL
    GarethL
    What version of the AVR300 software have you got ?
    I am using 2.90.
    I'm guessing that if my software version is the same or newer than yours then I have a slightly faulty unit.
    cheers
  6. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Mine's build 2.82.
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    I have version 2.99.
  8. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Mine's upto 3.01 now
  9. Duster
    Duster
    Dec 4, 2002
    421
    UK
    How do you find out what software version you have? Sorry im a new user :blush:
  10. GarethL
    GarethL
    I have just upgraded my software to 3.01. I am still experiencing the sound cut-out problems. Arcam have recommended I take the box back to my dealer - doh.
  11. Remboy
    Remboy
    Duster, press first 2 input buttons at once (DVD and SAT I think) and software version will show on display.
  12. Remboy
    Remboy
    ...and Gareth, can you let us kow how you get on? Would like to know from Arcam what the denitive cure is for this. Thanks.
  13. andyasb
    andyasb
    Jul 27, 2004
    126
    Surrey
    +11
    3.01?!!!
    ooo, is this the new software that has lip sync variable for inputs? is it available anywhere, or do we have to wait for aslgroup to publish?
    A
  14. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    No, that's not yet available. Andrew Dutton stated in another thread it's been done but still has to be tested for release.
    3.0.1 adds:
    RC5 code (System code 16, command code 84) to access the setup menu. This is so you don't have to press and hold a key when using a programmable remote
  15. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    Just spoken to ARCAM tech support about this as I have the same problem. The latest SW version is 3.0.8 and this also has the per-input variable lip-sync feature.
  16. GarethL
    GarethL
    When I installed 3.01 it didn't fix the problem. It has also introduced a new problem - Zone 2 no longer will follow Zone 1 - I keep setting Zone 2 to follow 1 and it keeps resetting itself to No Cntl. Could you try and see if 3.08 has had this new error fixed and let me know :)
  17. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    I have no chance of getting to my dealer to get the update until February at the earliest - and probably not till the end of Feb and since my unit is brand new I'm not going to do the update myself.
    Also I can't find it on the web - the latest on aslgroup is still 2.9
  18. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    I have formally reported this bug to Arcam. Let's see if their technical support process is up to scratch. So far I have not even had an acknowledgement!
  19. Duster
    Duster
    Dec 4, 2002
    421
    UK
    When I email them, I got a reply in about 3 days
  20. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    They've replied - now we just need to wait for an update with the fix.
