AVR300 software upgrade
J
Jim_R
My notebook computer does not have a serial port. Can I perform an AVR300 software upgrade using a serial/USB adapter?
Sparky66
If you are using a USB to Serial adaptor, do you still need a null modem cable attached to this for communication ?? :confused: :confused:
RaceTripper
An adapter is just that. In adapts the USB port to a serial port. You still need the correct cable.
Trending threads
