AVR300 Software Update
Discussion in 'AV Receivers & Amplifiers' started by niceguy235uk, Jul 25, 2005.
Tags:
  1. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,871
    83
    +272
    I know this has been discussed to death but my software seems very 'old' comparedto most peoples here and i was just wondering whether it is worth me getting it updated. I have no problems or issues at all with the amp so im not sure its worth it.
    Advice appreciated
    Regards
    Jason :)
  2. Hifi addict
    Hifi addict
    if it ain't broken then don't fix it ;)
    but just go through the release notes (sticky in this forum) and see if there is something usefull for you. (like lipsync PER source). If there is nothing you need, then don't bother the disconnect, transport to your dealer etc etc. Unless you can update the AVR300 yourself.
  3. clauser
    clauser
    Jun 29, 2005
    57
    Can you tell me where to get the AVR300 V3.28 software ? I can upgrade the AVR300 myself. Thanks ...
    Kind regards,
    Erwin
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    From me if you ask really really nicely.
  5. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    I'd love to do the latest update as my AVR300 was one of the first available, but am not sure how difficuult it would be? what do you do? I am a fairly competent electrician but I do not know what equipment I'd need?
    The main reason is the volume control thing, my AVR300 is almost always on above 70-75.
    How easy is it Crustyloafer? and could/would you please, please, please supply the upgrade?
    Thanks guys
    Chris
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I'm not aware of any fixes in the firmware updates that affect the volume control operation.
    If you PM me with your e-mail address I can forward you the relevant files and instructions.
