AVR300 software update
Discussion in 'Arcam Owners' Forum' started by Playitloud, Apr 26, 2005.
  1. Playitloud
    Playitloud
    Jun 4, 2004
    11
    Chelmsford
    +3
    I am currently running my AVR300 with the software version 2.90/ DSP 1.12.
    It performs excellently and presents me no problems.
    Would there be any benefit gained by updated to 3.16 which I believe is the latest.
    I have read the thread with the list of fixes & additions to version 2.90 but do I just leave well alone?
    Any replies would be appreciated.
  2. GarySargent
    GarySargent
    Jan 19, 2005
    50
    Stick on 2.90 if you're happy with it. I was on 2.90 for a while with no issues, and didn't really notice anything going to 3.16.
  3. GarySargent
    GarySargent
    Jan 19, 2005
    50
    Oh except there is a bug in 2.90 changing processor and effects modes - used to register a double key press sometimes which was really annoying. If you often change these settings the upgrade will fix this.
  4. Playitloud
    Playitloud
    Jun 4, 2004
    11
    Chelmsford
    +3
    Thanks for the reply Gary,
    Not really experienced this bug so will stick with 2.90 for now.
    As they say if it aint broke don't fix it!!! :thumbsup:
  5. roffe
    roffe
    May 30, 2005
    55
    How do you know what kind of DSP version you have?
    I know that pressing the DVD and SAT buttons reveal the firmware version, but it does not show the DSP version...
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    If it does not show the DSP version then it is likely to have version 1.10. You will need to update this to version 1.12 before applying any firmware updates otherwise you are likely to end up with a non functioning unit.
  7. roffe
    roffe
    May 30, 2005
    55
    OK, thanx. I assumed I didn't have DSP 1.12 anyway, to be on the safe side.
    Just out of curiosity: What is the difference between DSP 1.10 and 1.12 from a daily use point of view.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    I found it improved the steering of effects and general accuracy of the DD and DTS processing.
