AVR300 remote code for pace V2 Sky+
Discussion in 'AV Receivers & Amplifiers' started by Starkiller, Jun 10, 2005.
Tags:
  1. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    anyone got this code
    its not listed in the hand book
    I would have thought this would have been one of the most widely used codes for Sat, cant understand why its not listed :oops:
  2. hedrick@rutgers
    hedrick@rutgers
    May 9, 2005
    57
    You do know that the remote will learn? If you have a remote for the Pace unit, you should be able to copy the code to the AVR300's remote. (I'm assuming it's the same as the AVR250, which is what I have.)
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    I concur, I had to teach the CR80 remote the commands from my Sky box and then only the ones I really needed and the memory is very limited on the CR80 remote.
  4. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    thanks,
    maybe arcam could add this to there future products, im sure it would be popular
