AVR300 Question
Discussion in 'AV Receivers & Amplifiers' started by joeyvaz, Sep 19, 2004.
Tags:
  1. joeyvaz
    joeyvaz
    Hello All,
    I am a proud owner of an AVR300. I have it for a couple of weeks and absolutely love the sound quality. Really makes my Energy C-7s come to life. It's a great step up from the DenonAVR-1083 that I previously had pushing this setup.
    I do have a question regarding the fact that I don't have any output from my sub with any of the sound modes. The only time my subwoofer comes to life is when I listen in stereo mode. I have the AVR300 configured with large+subwoofer on at all times. Yet there is still no output to the sub in any other mode than stereo. I know I must be missing something, so your help will be greatly appreciated.
    Edit: I can get it to work by changing all the speakers to "small" My question is if I can get the subwoofer to play with all my other speakers set to "large".
    Thanks,
    Joe
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    If you have all the speakers set to large then it will only send information to the subwoofer if it is receiving a signal from the DVD player with a 5.1 soundtrack, it will then send the .1 signal to the subwoofer. Make sure you have your DVD player set to output a 6 channel bitstream signal via the digital interconnect.
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    You should also disable your Sub's crossover (or set it to max freq. if it can't be bypassed), and use the AVR300 Sub crossover setting instead. A good starting point is about 80Hz, but it also depends on your speakers freq. response. Salt and pepper to taste.
  4. joeyvaz
    joeyvaz
    Thanks for the imput. I really appreciate it. I left the speakers set to small for now. I'm getting a new DVD player this week that has more adjustments on the audio side. Once I get it, I'll take the suggestions listed below and tweak from there.
    Thanks,
    Joe
