AVR300 OSD Question
Discussion in 'Arcam Owners' Forum' started by dfindlay, Mar 14, 2005.
  1. dfindlay
    dfindlay
    Jun 3, 2004
    Ottawa, Ontario
    I have my video source outputs plugged directly into my TV (i.e. not thru the AVR) The problem with this arrangement is that I don't see OSD. Is there any way to remedy this? For instance, could I connect one of the lower quality a/v interconnect choices and see the OSD or would the higher quality connection override this?
    Thanks in advance...
  2. TimHiFi
    TimHiFi
    Feb 2, 2005
    84
    Reading
    The Monitor Out standard composite has the OSD on it.
    I too have not connected up the AVR300 video side, but if you plug Monitor Out into a spare input on the TV, you will be able to set it up.
  3. dfindlay
    dfindlay
    Jun 3, 2004
    Ottawa, Ontario
    Thanks TimHiFi - I had already done what you advised and I can see the OSD for the channel whose input I've used but not others.
    However, further reading of the manual may have enlightened me. What I'd most like to see is the popup volume graph and apparently this is not available when your display device is set for progressive scan. I'm not sure why I can even see it on one input if this is the case except that I only use the source involved for display for low quality image from my PC.
  4. GarySargent
    GarySargent
    Jan 19, 2005
    50
    Is the background for the OSD supposed to be grey?
    Maybe it is supposed to be, but it just looks like it is outputing some non PAL signal or something, doesn't seem quite right.
    I too am just using the monitor S-Video out. No video inputs connected.
  5. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The AVR300 OSD background is supposed to be grey.
    Regards,
    Andrew
  6. GarySargent
    GarySargent
    Jan 19, 2005
    50
    Thanks Andy - just expected it to be blue or something and wondered if something was wrong :)
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    In order for you to see the OSD and volume scale onscreen whilst watching other sources you need to route the sources through the AVR300 so that it can overlay the graphics over the video source. As you have already noted this will only work for interlaced video sources.
  8. dfindlay
    dfindlay
    Jun 3, 2004
    Ottawa, Ontario
    Thank you Crustyloafer for clearing things up.
