AVR300- One cable to my Plasma
Discussion in 'AV Receivers & Amplifiers' started by Barend, May 12, 2004.
Tags:
  1. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Will it be possible to use just the component cable to my Panasonic plasma?
    My inputs to the AVR300 will be:
    1. DVD comp.video progressive scan
    2. Sat receiver thru converter component video
    3. VCR - ordinary single yellow plug
    4. And the AVR300 setup
    Not very elegant to switch the TV too...
    Barend
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,436
    Newcastle
    +272
    Yes. The AVR300 will upconvert your video (composite) to component, and you can then switch between all 3 inputs to a component output.
    Cheers,
    Liam
  3. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Thanks!
    Much less yelling from my wife expected "Wrong sound again!".
    Barend
  4. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
    You will need to be careful with the VCR, unless it has TBC (time base correction) then it will not work. This is a very common problem with the Denons which use similar format conversion.
    I flagged this as an issue with Arcam along time ago, but i am unsure as whether anything was ever looked into....
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    There's an alternative to using video switching
    If your TV has discrete IR codes for inputs you can also use a remote that supports macros and make direct video connections.
    I use an AVR300 with a Samsung DLP, and use my remote (HTM MX-700) to simultaneously switch inputs on the AVR300 and TV. It never fails, and I probably get somewhat better quality by having direct audio and video inter-connections, not to mention I don't have the expense of duplicating my best video cable.
    Dean
  6. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    To answer Elliott's warning about not using the AVR300 video upconversion circuitry with a non TBC VCR - so far we haven't found a VCR that doesn't work with the 300, including a truly grotty one owned by a member of our engineering team.
    So the answer is that we do expect most VCRs to work properly - though there will no doubt be exceptions and so we will not guarantee this. We did listen though :)
    HTH.
    John Dawson (Arcam)
  7. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
    Excellent stuff John, and really pleased to hear it :)
    This is a real pain in the arse otherwise :clap: well done :clap:
  8. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    "a truly grotty one"
    I can picture it now....
    Matt
