AVR300 no sound until 40db
Discussion in 'AV Receivers & Amplifiers' started by Scuba_Steve, Feb 2, 2009.
Tags:
  1. Scuba_Steve
    Scuba_Steve
    Just set up my new AVR 300 and I dont seem to get any sound until the volume is over 40db, is this correct and working fine or is my amp working to hard?
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    It's normal - the gain is in decibels and you get to hear stuff at normal listening levels on average sensitivity loudspeakers in the 50 - 70 dB range. 80-ish will be pretty loud :)
    HTH
    John Dawson (Arcam)
  3. Scuba_Steve
    Scuba_Steve
    Thanks for the quick reply and puytting my mind at rest, iv just upgraded from the Arcam A75 where you get 'sound' right from the bottom of the volume scale, which is why i was confussed :)
  4. Scuba_Steve
    Scuba_Steve
    Just wondering why there is only sound when the radio is on at a db level of over 80db...
  5. Jaunty
    Jaunty
    Feb 7, 2006
    2,488
    83
    London
    +298
    From the AVR250 Manual:
    ADV 5 – Analogue Settings
    Input trims: Allows the adjustment of the input sensitivity of the analogue inputs (in
    Volts rms) so that each one achieves the optimum dynamic range and sounds similar in
    loudness to the others.
    Available level settings are: LOW 0.5V, MEDIUM 1V, REFERENCE 2V, HIGH 4V. The
    reference level of 2V should be appropriate for most inputs.
    If a source is very quiet compared with the other sources you can increase its loudness
    by selecting the MEDIUM 1V or LOW 0.5V settings.
    Might help
  6. Jaunty
    Jaunty
    Feb 7, 2006
    2,488
    83
    London
    +298
    Whoops - radio presumably is the one in the receiver?? In which case ignore the previous post...
