AVR300, need help getting zone 2 speakers to work
Discussion in 'Arcam Owners' Forum' started by siskel16, Jun 26, 2005.
  1. siskel16
    siskel16
    Hello all :)
    I connected a set of outdoor speakers to the zone 2 speaker connections and I hit the zone 2 button on the front of the received, adjusted source and volume but no sound is coming out.
    Has anyone successfully added zone 2 speakers? Am I missing a step?
    Thanks!
    Siskel
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    I am at home and don't have an AVR300 to hand but from memory you need to change the setting in the Setup menu for channels 6+7 to read Zone 2. It normally defaults to Surround back L + R (I can't remeber the exact text but that is the operation).
    Just look through all the menus till you find it as I can't remeber which menu it is in.
    Regards,
    Andrew
  3. PMorali
    PMorali
    Also, make sure your sources are connected the analog interconnect...
