AVR300 menu
Discussion in 'Arcam Owners' Forum' started by newbie265, Dec 23, 2004.
  1. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    Is the only way to get the setup menu on screen using composite leads ,Sevenoaks set up my system but didn't turn my sub on for music and I want to try it?
  2. Icarus
    Icarus
    On the rear of the AVR300 there is a socket marked video monitor out - I used to use that before component leads and it works well enough for getting at the menus.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    You can use composite, s-video or component to get the on screen display up on the screen.
    You can also navigate the menu from the display on the front of the AVR300, although you really need to know your way around the menu to be able to do this successfully.
  4. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    ok sorted guys ,cheers :thumbsup:
    Does anyone know whether you can get the sub working when using dolby and music pro logic on sky?
  5. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Certainly works via my NTL box. Just need to configure the sub/ speaker in the settings pages.
