AVR300 - local remote extender required
Discussion in 'AV Receivers & Amplifiers' started by parrydave, Jul 27, 2004.
Tags:
  1. parrydave
    parrydave
    Hi all,
    I have an AVR300. It sits on the bottom shelf of my rack and is partly obscured by a sofa. Looking in the user guide, i see there is a "Local remote-in" socket. Any ideal where I can get an IR receiver to plug in here?
    The manual recommends a Xantech product for use with Zone2 remote-in. Would the same item work for the local remote-in? It isn't explicitly stated in the manual for use as a local extender, only a Zone2 extender.
    thanks.
    Dave
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The same part will work for the local in.
    Regards,
    Andrew
  3. parrydave
    parrydave
    Great Andy.
    Thanks for help
