AVR300 flashing stand-by
m1964
Established Member
second day after coming home I want to turn on my system (TV, AVR, cable box) - AVR300 does not turn On. On closer look I noted flashing orange stand-by light. No mention in the manual's trouble-shooting section about it.
Anyone w/ same problem?
PS
After turning it Off/On using the button works fine (so far).
I am using universal Logitech remote control.
I would appreciate greatly any input.
Crustyloafer
Give Arcam technial support a call. A flashing orange stand by light sounds like an indication of an internal fault or some sort of short circuit at the speaker terminals. First thing to try is disconnecting all cables from the AVR300 aprt from the power cord and see if it solves the problem. If it does reconnect everything a bit at a time which may highlight where the problem lies if it is a cabling issue.
m1964
Established Member
it has been working fine since then, so I did not call tech support (was busy too). I might call in future just to find out what may cause such a thing.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
