AVR300 cooling fans update
Discussion in 'AV Receivers & Amplifiers' started by zamwessell, Aug 10, 2004.
Tags:
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,196
    +120
    Got my replacement AVR300 on Saturday.
    The fans have not fired up and even made it through the hottest night of the year without being activated.
    My dealer said there was a small batch which had a fault Arcam are aware.
    So everything is cool (ahem).
    Thanks to Arcam for the support.
  2. bedders
    bedders
    Apr 29, 2003
    224
    UK
    So for those of us who are registered AVR300 owners, will Arcam be contacting us if they identify that 'our' model is affected?
    TIA
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    No Arcam are unlikely to be able to identify if you've been given a faulty unit without you telling them. If the fans come on all the time or at least very prematurely then take it back to your dealer who will be able to arrange a replacement or repair.
  4. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Watercooling could be solution
    Like in that famous thread :)
  5. JetJockey
    JetJockey
    I have to drive 400 miles to return mine (don't ask). I am really ****** off.
    I may also reject the DV79 as a result.
    Gerald. :mad:
