AVR300 compression mode
Discussion in 'Arcam Owners' Forum' started by seanb724, Aug 24, 2005.
  1. seanb724
    seanb724
    Is there a discrete IR code to toggle through the compression modes or do you have to do that via the menu?
    Thanks,
    Sean
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Menu only I'm afraid, I checked all the discrete codes in the manual and there isn't one listed for that feature. It might be possible for this to be added in a future firmware update.
