AVR300 centre speaker "low sound" problem
Discussion in 'Arcam Owners' Forum' started by bedders, Apr 9, 2005.
  1. bedders
    bedders
    Apr 29, 2003
    219
    UK
    Hello,
    Not sure why, but the sound out of the centre speaker has all of a sudden gone soft as if the volume is very low and 'tinny'. All other speaker volumes sound fine, it's just speach etc from the centre speaker having this problem.
    S/W 3.08 and 1.12
    Happens with DVD (Arcam DV88Plus via digital coax), and TV which is via L/R audio from Hitachi 42PD3000.
    THX sound test from The Village DVD sounds ok from all speakers, inc centre.
    When I watch 'The Village' DVD the speach from centre is soft whether it's DD or DTS, although when I switch AVR300 DTS mode from "DTS 5.1" to "DTS S Dmix", the centre speaker sound is normal!
    Have checked cable connections, and this happens on all DVD's we've tried.
    Centre speaker is a Mission 78C.
    Any ideas anyone?
    Many thanks in advance...
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,522
    Edinburgh
    +1,241
    Something not right there, if you set the AVR300 to 'DTS S Dmix' this will downmix the sound to stereo and should therefore only come out of the front left and right speakers and not the centre speaker at all.
  3. bedders
    bedders
    Apr 29, 2003
    219
    UK
    Silly me! It's late here in the UK and i'm tired :eek:
    You're right, DTS S Dmix is only coming out of the front L/R speakers. So I can exclude that from my post.
    Thanks for the quick spot Crusty :smashin:
