PhillMarls
Established Member
As owner of a newly accquired AVR300, I'm eager to try bi-amping my ProAc Studio 125 front speakers in stereo.
Does anyone have aural evidence with their setup to say it is worthwhile doing this, as I'm only 5.1 cinema setup currently.
Is it really important to use the same spec cable for high and low frequencies to get the best results? Not sure I want to buy another set of Chord Odyssey and find it makes no or very little difference, would a cheaper Chord cable for high frequencies be OK?
Does the direct mode work OK even though you are using all 7.1 channels?
Any advice welcomed please!!!
Phill
Phill
