AVR300 bi-amp question: what happens when you press Direct?
Discussion in 'AV Receivers & Amplifiers' started by zm10, Sep 21, 2005.
Tags:
  1. zm10
    zm10
    Leaning towards buying the AVR300 for my HT system that's being put together from scratch.
    If you bi-amp your two fronts on the AVR300, what happens when you press Direct?
    If I understand the Direct button correctly, it turns off all digital circuits so that you have only 2 channel anologue stereo from the audio inputs only. So does that mean the speaker output for channels 6&7 used in bi-amping aren't powered when you press Direct? This would render the use of bi-amping and Direct together a no no on the AVR300. True?
    Thanks.
  2. tvh3ad
    tvh3ad
    Jan 19, 2005
    339
    +15
    This feature must not be part of the DSP because bi-amping does indeed work when in direct mode.
  3. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,871
    83
    +272
    When i had a 300 i initially had my fronts bi-amped through 6 & 7.
    Worked a treat in Direct mode. :smashin:
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    There are 7 discrete channels of amplification in the AVR300. Biamping is just a case of routing the analogue signal to 4 instead of 2 of those amps. This should not require any major DSP algorithms to decypher.
  5. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    The thing to note is that with bi-amping, both amps are fed with the same signal - there is no electronic crossover before the power-amps.
    This is different from multi-amping in pro PA systems, where you have mulit-way electronic crossovers in front of the multiple power amps.
