AVR300 and gaming
Discussion in 'AV Receivers & Amplifiers' started by kgulls, Jun 29, 2005.
Tags:
  1. kgulls
    kgulls
    Mar 6, 2004
    341
    Devon
    +20
    Can anyone help on this one please :confused:
    I have the PS2 connected via both optical and 2 channel into the AVR300 but I'm unable to configure the set up to output any sound through the rear speakers.
    The display shows permanently as anologue even though I've assigned the outputs correctly in the digital output menu and the optical setting on the PS2 is set to on.
    Even if the optical output isn't working why is it not possible to use the effects button to create a pseudo surround effect from the anologue connection.
    Any suggestions please. :)
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Check to see if you have the direct mode switch on. This forces the AVR300 to always use the analogue input even if digital is avaiable.
    Regards,
    Andrew
  3. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,433
    Cornwall
    +100
    My setup, AV input on the AVR300 set to an optical port, PS2 set to optical on, surround mode set to DDIIX. Works for me.
    You say "through the rear speakers", does this mean the fronts are working? (which would imply that the avr300 is accepting the optical connection).
  4. kgulls
    kgulls
    Mar 6, 2004
    341
    Devon
    +20
    Will check to see if direct mode has been enabled somehow.Thanks Andy.
    Matt,yeah the sound is fine from the front speakers.If I press either the mode or fx button on the remote I get the message "Not available".I have the Ps2 on the Sat input and X-box on Av input and the X-box is fine and outputs DD.I even swapped optical cables to see if that was the problem.
    Will try Andys suggestion out and hope thats the answer. :)
    Incidentally,if the analogue only connection were used should the DSP fx button not work?
  5. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    Almost positive direct mode is on.
  6. kgulls
    kgulls
    Mar 6, 2004
    341
    Devon
    +20
    Yep,direct mode switch was on :oops: Problem sorted.
    Another success for the forums.Thanks guys for your help :smashin:
    Keith
