AVR300 4 ohm fronts and 8 ohm surrounds
Discussion in 'AV Receivers & Amplifiers' started by tcousins1, Jun 15, 2005.
Tags:
  1. tcousins1
    tcousins1
    Hi-
    I am new to the forum but have always enjoyed the info it has to offer. I have just acquired some Genesis speakers that are 4 ohm for the front and have for now 8 ohm surrounds. With the AVR300 in 4 ohm mode am I ok with the rest of the system?
    Also- Is there any experience out the with the Monitor Audio Gold Ref. 20's? I have two AVR300's and am looking for a good pair of Stereo/HT fronts for under $3000 that can fill up a 20'x20' room.
    Tom
  2. Hifi addict
    Hifi addict
    yeap, 4 ohm would be fine in this setup.
    on your speakers: you could also try Sonus Faber or B&W.
  3. tcousins1
    tcousins1
    Do I keep the switch on the back at 4 ohm?
  4. Hifi addict
    Hifi addict
    yes. always keep the setting adjusted to the most "difficult" speakers
  5. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Intresting... even when most are 8ohm?
    My fronts and backs are custom speakers and are rated at 8ohms but they are efficient as hell.. also my centre is odly at 6ohms...
    should i flip it back to 4 ohms?
