avr2805 svideo in to component out switching
D
dest
I've been trying to set up the video switching function on the 2805 I have a monitor connected to the component o/p and a terrestrial digital box connected to Video 1 component i/p via harddisk recorder. This works fine.
I have another digital terrestrial box connect to VDP svideo i/p and, for testing, a video camera connected to VCR1 composite video i/p
I cannot get either of these two source to switch the the component o/p. Audio switches ok.
The video switches between VDP and VCR1 as it should when connected to the svideo/composite monitor o/p and the OSD works fine on that o/p
Any ideas on how I can route svideo or composite video to the component o/p?
A.
D
Deleted member 30535
What is your VIDEO INPUT MODE set to for each of the sources?
D
What is your component input assignment set to for the VDP and VCR? It's menu option 3-3.
I've just done a test on my set up. Granted I haven't got all your gear, ut the principal remains.
I disconnected my DVD component lead to make sure that was not providing a signal. I then connected a S-Video out from the DVD to the VCR input. With the TV still conected on the Component out from the amp, I switched input to VCR when the DVD was playing. Sure enough I got the S-Video converted to component which appeared on my TV.
Interesting that when you have a component source being routed via the amp, the OSD for the volume up and down doesn't work, but it does work if upsamplig from S-Video to component (i.e. the OSD "volume" appears on the component signal).
The component input assignment on the VCR in the 3-3 menu was set to none.
HTH. If it doesn't, perhaps you have faulty upsampling?
D
dest
thanks for taking the time to test this out.
My component inputs for VDP and VCR are set to NONE
I also disconected everything as you did and, unfortunately, only get audio switching.
I'm hoping its not a fault. I've contacted Denon but no response as yet.
A.
D
A long shot now........
Have you got ANY component signal from your AMP to display on your monitor? Do you run your DVD directly to your monitor or through the AMP?
I remember reading a recent thread in here that stated the component out on the Denon is interlaced and that a monitor that was being used was progressive scan capable. The result: no picture. I think a quick test was done by switching the output of the DVD from progressive to interlaced and no picture was the result. Progessive component will get fed through the amp unhindered I think, but any conversion is to interlaced.
As I said, a long shot.
D
dest
ah you may have something now.
but to answer your first question yes, I do have a component signal from the amp when the hard disk/DVD unit is i/p on component in. This give me a 576p signal at the monitor.
my tv can display 480p, 576p or 1080i
So you are probably correct with your long shot :(
Damn, that is annoying I don't remember seeing that the conversion was to interlaced in the manual.
I have noticed that there is no down-conversion from component to svideo either, although I think I do remember reading that is the case in the manual.
The system is:
Terrestrial box: Sony DV3
connected by Scart RGB to
DVD/HD: Panasonic DMR-E95H
connected by component to
Receiver: Denon AVR 2805
TV: Philips 30pf9975
and then second terrestrial box: Goodmans GBD2
connected by svideo to
Speakers: Mordaunt-Short Genie
Thanks again for your help
A.
D
No problem. That's what these forums are all about. :)
