AVR2805 good enough with QUAD 12L cinema
Discussion in 'Home Cinema Speakers' started by DrumNBass, Mar 6, 2005.
  1. DrumNBass
    DrumNBass
    I've been thinking of buying the QUAD cinema package based on the QUAD 12L fronts. I want to get the fronts and centre now (using my current missions as rears) and at a later date get the 11Ls as rears and also guy the QUAD sub (when I move out of the 3rd floor flat). However given my current budget I'd only have about £600 left for the AMP, is the 2805 going to be good enough for this setup?
    thanks in advance.
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I heard the QUAD 11L with the Denon 3805 with great results!
    I think they can do a good match even if they sound better with a better amp (as allways).
    Go an try it! Or try the Marantz SR7500 too at a similar budget...
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I'm currently running the SR7500 with Quad 21L's and it drives them very well indeed, they make a great team too :)
  4. krungthep56
    krungthep56
    Oct 1, 2004
    178
    Cheshire
    +6
    Hi Drum'n'Bass,
    I have the Denon 3805, linked to the 3910 DVD player via Denonlink, and at the moment am playing through a single pair of 11L's.
    The sound with good material is superb, although the Quads do depend upon good quality fodder.
    Am sure the 2805 will be up to the job, what source player will you be playing through?
    Another factor to consider is that I am sure that you'll want to keep the Quads and they will outlive your receiver.
    Regards,
    HT
  5. DrumNBass
    DrumNBass
    I'm currently playing through an old Marantz CD 63SE anda Pioneer 565A DVD player. I "may" upgrade both at some stage although I may wait a year or so and invest some kind of good quality streaming device.
    I had a demo of the QUADS today, fantastic, I'll put up a seperate post about that.
