AVR250 - Sudden Problems
Discussion in 'AV Receivers & Amplifiers' started by oariel, Jun 30, 2005.
Tags:
  1. oariel
    oariel
    After approximately 5 months of smooth operation with full 7.1 configuration (very happy with the overall quality and power!) I have started all of a sudden to experience problems with my AVR250. The symptoms are:
    ANALOG mode (input from Sat, Xbox): Loud static noise (I believe it is described as ‘frying bacon’) over the original soundtrack that sounds garbled.
    DIGITAL 5.1 Mode (DVD from DV78 Coax): Inconsistent behavior; sometimes it would decode smoothly, or not decode at all or may sound garbled.
    DTS (DVD from DV78 Coax): Last I tried was OK
    Anyone experienced similar symptoms? Is there a quick fix or is there is something terribly wrong with this receiver?
    Thanks!
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    Call your dealer.. sounds knackered.
