AVR250/DV79 sound modes
Discussion in 'Arcam Owners' Forum' started by stickybz, May 10, 2005.
  1. stickybz
    stickybz
    Apologies for asking such a basic question, some previous threads come close to an answer but not quite!
    Im not sure if its best to disable PL modes on the DV79 and let the AVR250 amp do any processing. If its preferable to let the DV79 do it, do you have to change its setup every time you switch between playing DVDs and CDs?
    Also if both DVD and amp have processing modes enabled does one stop the other doing it; or is this all a matter of taste best discovered through trial and error?
    One last Q to show just how dumb I am, read this in a review but not sure if its saying using dv79 in stereo is limited compared to other modes??
    "The only problem is that
    the DV79 is only capable of 24bit/48kHz
    stereo performance, so you’ll have to
    use the optical output surround sound at
    full quality."
    Thanks in advance :thumbsup:
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    The PL2 processing only comes into use if you are using the analogue outputs from the player. It is really only necessary to use this feature if you don't have an up to date processor or AV amp.
  3. stickybz
    stickybz
    Cheers for the help crusty :D
