AVR250 - Direct Mode
Discussion in 'AV Receivers & Amplifiers' started by roger hayhurst, Feb 22, 2014.
Tags:
  1. roger hayhurst
    roger hayhurst
    Feb 22, 2014
    3
    Although my AVR250 can do all kinds of complicated things, all I use it for is for stereo FM.
    The setup is remarkably simple: I have an FM aerial feed and two speakers.
    When I bought it (new) I freaked out when it was silent. It was only when I switched it from PLII Movie to Stereo Direct that it made any sound.
    I haven't changed it since but now either my speakers or more likely my ears need a bit extra treble.
    The problem is that I only get any sound at all if it is on 'Stereo Direct'. It is silent in 'Stereo' and anll other modes.
    Am I doing something particularly stupid? Am I having yet another 'senior moment'?
    thanks.................
    R
  2. nrighton
    nrighton
    Jul 5, 2009
    274
    28
    Fresno, California
    +56
    The "Stereo Direct" mode bypasses all digital processing. If you are hearing no sound in any other modes you may have a problem with the digital signal processing board on the AVR.
  3. roger hayhurst
    roger hayhurst
    Feb 22, 2014
    3
    Oh dear! That sounds expensive! I wish I had persued th issue when I first bought it.
    I shall have to connect and check some othr inputs.................
    R
  4. roger hayhurst
    roger hayhurst
    Feb 22, 2014
    3
    so, is there an unequivocal test to determine if the DSP board is working or not?
  5. AshleyH
    AshleyH
    Jan 1, 2008
    16
    3
    +5
    Plug in a cd or DVD player using either an optical or coaxial digital lead Nd see if you get any sound.
    But as others have said, it sounds like a blown board. There is some way of doing a factory reset I believe,
    Though this is unlikely to cure it.
    I think the amp would be uneconomic to repair now, so probably best just to continue to enjoy it in 2 channel a Stereo Direct mode.
