avr200or3802
Discussion in 'AV Receivers & Amplifiers' started by teknosys, Nov 27, 2001.
  1. teknosys
    teknosys
    Nov 25, 2001
    218
    16
    london
    I am also interested in avr200/dv88 was wondering if dealers holding back release due to existing stock of avr100? however how would denon 3802/dv2800 compare. also is the2802 advetised on german site an updated model?
  2. robocook
    robocook
    Nov 6, 2001
    121
    19
    Sevenoaks, Kent
    The replacement for the DVD2800 is to be the DVD2900, some post about this on the avsforum and it is on some Japanese e-comm sites and it will use a different prog-scan chipset. When this comes out is anybody's guess.
    Seems that a lot of dealers are marking down AVR100 stock to clear them... mind you the Denon combo can be had for £1250 and the Arcam 200/DV88 is £1800 - mind you guess it's what it performs like really.
  3. teknosys
    teknosys
    Nov 25, 2001
    218
    16
    london
    thanks for the response.where can you get denon combo for £1250?
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Hi teknosys,
    I am pleased that you are interested in Arcam equipment for your home cinema needs.
    Well over 100 Arcam dealers already have the AVR200 in stock and on demo, including many in the London area. If you e-mail me with your precise location I would be able to direct you to a nearby dealer who would be able to demo the DV88/AVR200 combo for you.
    Whatever you choose to buy I would recommend getting it from a local dealer from whom you can can get a decent demo and always turn for advice and support should you ever need it.
    Sincerely,
    John Dawson (Arcam)
