AVR200 Manual
Discussion in 'AV Receivers & Amplifiers' started by rv02, Feb 28, 2005.
Tags:
  1. rv02
    rv02
    Does anyone knows how I can get hold of AVR200 Manual. I have lost mine and can not find anywhere on the web for a pdf file or similar format.
    Also does someone knows whether this system has on disply setup and if so how can i access this.
    Thanks in Advance
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    To get the onsceen menu you need to connect the 'Monitor out' connection to your tv and you also have to feed a signal of the same type into the amplifier. For example if you take composite out of the 'monitor out' connection you need to feed a composite signal into one of the video inputs in order to get the onscreen display to work. Once you have done this pressing 'up' on the cursor control on the remote should bring up the onscreen display.
  3. rv02
    rv02
    Thanks for this.
    Just to clarify this i understand the connction from Monitor out to TV I use composite, can someone clarify the what it means or how do I take the composite signal to the video inputs (is this for the audio bit or something else).
    Sorry for my ignotance.
  4. IanDH
    IanDH
    I have a copy of the manual as a .pdf file (998KB) downloaded from the Arcam site while this was still a current model (also still have the AVR200).
    Can't see how to attach files to replies. If you want to PM me with you e-mail address I'll sent you a copy.
    Ian
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    You need to take composite signal from your DVD player or any other video source for that matter and plug it into one of the composite video inputs on the back of the amp before it will output the onscreen display. I know it seems silly but that's the way it works, the AVR200 cannot generate its own 'Sync' signal and therefore needs one fed into it from another device.
  6. mrkeeling
    mrkeeling
    I have nothing connected in video IN, just (composite) monitor out from my AVR200 to my monitor and OSD works just fine. :thumbsup:
    Truth is, it is a LCD monitor – maybe it doesn’t need “Sync-ing”. :D
