AVR200, DV88+ with Sky+ connection to Panny pw7
Discussion in 'Arcam Owners' Forum' started by iranu, Jan 13, 2005.
  1. iranu
    iranu
    My father is looking into the Panny pw7 but is confused (as am I :blush: ) as to the best way to connect everything to the screen (preferably with only one connection to the screen).
    Having tried a lot of searching here I've come up with the following
    Sky+ > AVR200 using s-video
    DV88+ > AVR200 using component video.
    AVR200 > pw7 using component video terminal board.
    Is that the best way of connecting the above two with Sky+ box?
    The sky+ box has vga/s-video/composite out.
    Any help will be greatly appreciated. :)
  2. PTG
    PTG
    Any help will be greatly appreciated. :)[/QUOTE]
    Sky+ > Svhs to component "convertor box" > component AV200
    DV88+ > component AV200
    AVR200 > PW7 Component board
    PTG
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Doesn't the AVR200 only have composite and s-video switching? I think you need the AVR300 if you want components switching (as well as upconversion for s-video).
  4. iranu
    iranu
    Thanks, I think the AVR300 might be an option as he's thinking of going the extra mile. :) Might be a bit more of a persuader if AVR200 doesn't support components switching.
    So may consider as suggested by HD in another thread.
    Sky+ > JS RGB to component > component AV300
    DV88+ > component AV300
    AVR300 > PW7 Component board
    I presume at this point that Svhs and RGB are equal in picture quality, so going for the JS Tech RGB > YUV is the easiest/best option.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    RGB is better than S-Video.......hence RGB>component is better than S-video> Component
    If he sticks with AVR200 the DV88+ direct to component board and Sky via RGB>VGA to VGA input and bypass AVR for video
  6. iranu
    iranu
    Brilliant thanks very much for your time and help.
