AVR200 Discrete codes for a Pronto
Discussion in 'Home Cinema Control & Remote Controls' started by raven219, Jan 12, 2003.
  1. raven219
    raven219
    Mar 5, 2001
    532
    East Angular (near Tunisia)
    +15
    Anyone found the discrete IR codes for powering off/on an AVR200 unit?
    Niall
  2. SgtRock
    SgtRock
    Niall,
    Try pasting a code for the AVR200 from the pronto, then see if you can decode it with irtool and then use prontoutil to create a complete series of codes for the device.
    One code might work.
    Wish I'd have known about irtool before I decoded a JVC code I was looking for by hand.
    Or PM me a code from the AVR200 and I'll PM you back a complete series of codes.
