AVR200 Bass Management question
Discussion in 'Arcam Owners' Forum' started by hifigramps, Jun 10, 2005.
  1. hifigramps
    hifigramps
    Can someone tell me what the x-over point is when you select small as the speaker size? The owners manual gives refrence to 100Hz as i.e. but does not give an actual x-over point. I assume if you select large, you get a full range signal.
    Thanks!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    I can't say for sure for the AVR200 as I don't own one and can't find a downloadable manual, but on most AV receivers you can set the crossover that best suits your speakers. It is not set by the speaker size setting.
    Mark.
  3. hifigramps
    hifigramps
    I agree with you. But, the AVR200 does not offer any crossover options. My AVR300 does.
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The crosover point on the AVR200 is at 200Hz (-typo error should have read 100Hz sorry-) as the manual says. This means that both the SUbwoofer output and the main outputs will be at -6dB and in phase with each other at this point so theoretically they will add to a flat signal.
    Regards,
    Andrew
  5. hifigramps
    hifigramps
    As good as the receiver sounds, I would call that really poor bass management.
    Does that mean when the speakers are set to large, every thing receives a full range signal and when set small everything below 200Hz goes to the sub?
    I have read every page in the owners manual and there is no reference to a 200Hz crossover anywhere in the manual. When I read your post, I checked it again. Nothing there.
  6. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Sorry that was a typo on my behalf should have read 100Hz.
    Regards,
    Andrew
  7. hifigramps
    hifigramps
    Andy,
    Thank you! That sounds much better.
