AVR200 and AZUR 640 CD how to connect?
Discussion in 'AV Receivers & Amplifiers' started by unrealdave, Jul 28, 2005.
Tags:
  1. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    I've been told that I should connect my CD player to the AVR200 via a digital link as opposed to the analogue links as the AVR200 converts the analogue to digital then back again through its own DAC – is this true? If so then there seems no point in using anything other than a transport?
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The AVR200 has an automatic analogue bypass internally. So it will not convert your DAC input back to digital unless you want to use any of the surround modes on the input.
    I would try it both ways as depending on how good your CD player is you may prefer the AVR200 internal DACs anyway.
    Regards,
    Andrew
  3. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    Thanks for the info - regarding the bypass - do you know if this is true of the AVR100 as well?
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Yes the AVR100 also has this feature.
    Regards,
    Andrew
