Quantcast
AVR for Thiel CS1.5's (3-4ohms)?
iwolf81
Hello all,
My Arcam AVR-100 has died after a decade of faithful service and I'm now looking for its replacement. I have Thiel CS1.5 main speakers, a Paradigm Studio CC v2 center, and Paradigm Monitors for surround speakers. The Thiels require a receiver that can power them correctly, but I'm looking for one around $1000. I know the NAD receivers can do the job, but the (relatively) lower priced ones are light on some desired features such as Ethernet connectivity. I would welcome any recommendation for receivers in the $1K range that could at least work with these speakers?
Thanks,
Ira
iwolf81
Where are you in the world? Would you be willing to buy secondhand?
I'm in Boston, MA, USA, Earth (Spyderco fans will appreciate the last location :) And, yes I'll consider second hand.
Thanks,
Ira
PSM1
If you are talking US$ in your budget you are definately going to have to go secondhand as anything new in that price range is going to struggle to power the speakers you have.
I am not sure what brands are available in your location (maybe a question in AVS Forums which is a US based AV forum may give better advice) but I would look for higher level but older receivers as long as you do not need all the new current features like 1.4HDMI etc. Hence look for older Arcams etc.
