AVR/Blu-ray settings
dobber24
Hi all my question is how to set the settings in the AVR/Bluray?
I have a Onkyo TX SR508
Panasonic BMP77 k
All the connections are with HDMI cables i have reset the AVR and Default the player
Still i get no dolby true hd
Plays in dolby digital which is fine but should run in DtrueHD
Any suggestions would be great
Player audio all set to bitstream btw
many thanks mike :thumbsup:
davepuma
Turn off any secondary audio or BD mix options off. I can't remember which ones apply to Panasonic but it's secondary audio (commentary) etc. which is set to on by default that prevents HD audio being bitstreamed.
dobber24
Ha ha i came home and started fiddling it actually says in the menu it gets converted to DD, doh! classic case of not reading the manual and kicking off why doesn't it work. slightly embarrassed.
And you was spot on Secondary audio as off when all as bitstream
Thanks again dave puma you're turning out to be my knight in shining armor ha ha :D
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
