AVR 588 help :-( red flashing light
Discussion in 'AV Receivers & Amplifiers' started by sarabellum, Jan 24, 2008.
  1. sarabellum
    sarabellum
    I have read all the troubleshooting tips...
    I have removed all speaker connections... ipod dock...
    only the unit is plugged into electric... and still after powering on... the red flashing light...
    I have reset the processor by pressing the a + b buttons during power up... no change.
    All my speakers have banana connectors, no wires were touching. Speakers are 8 ohms and woring properly.
    There is open ventilation...
    Is there a way to reset the unit from under the hood?
    I know this is probably very easy to fix... any suggestions are greatly appreciated!
    Thanks... Mike
  2. Jase
    Jase
    Mar 16, 2001
    10,873
    United Kingdom
    +3,050
    If you've tried everything as you've described then the unit has a problem and needs to be looked at. A reset would usually cure a DSP glitch and unplugging everything would eliminate any stray wires or dodgy connections.
