AVR-5800 (AVC-A1SE) upgrade manual
Discussion in 'AV Receivers & Amplifiers' started by MarkB, Feb 19, 2002.
  1. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,711
    Note the change on Surround Back speaker placement.
    They now say that both speakers should be as close together as possible!!
    Also the Bounday Gain Compensation for the sub.
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Hi Jase,
    What's happened to the channel level 'fuel gauges' ?????!!!!
    No mention of on screen volume indicator or and remote control updates. Comprehensive though.
    Mark
  4. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,711
    The Channel level gauges should still be there, they´d be mental to have taken that away!
    Did you spot the Power Amp assignment as well?? Though I´m not sure if our amps get this or it refers to the 5800 (it doesnt say, just 5800, like the tuner section further below it.)
    As you said it is a comprehensive upgrade, I cant wait!!
  5. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,711
    I think they might have got round the remote, as you now have to press Dolby multiple times to access PL2 etc etc
    Same applies to the other modes. There dont appear to be any changes to the remote screen (as shown in the pics.)
    cheers
