AVR-4306 not down converting Xbox-360
Discussion in 'AV Receivers & Amplifiers' started by BruceH, Mar 14, 2006.
  1. BruceH
    BruceH
    Dec 29, 2004
    260
    Weston-super-Mare
    +9
    My setup is as follows:
    DVD --> component1 --> 4306
    Sky+ --> S-video --> 4306
    X-box-360 --> component3 --> 4306
    4306 --> HDMI --> Screenplay 5700
    4306 --> Composite --> LCD TV
    DVD: visible on projector and LCD TV (Amp OSD visible on neither)
    Sky+: visible on projector and LCD TV (Amp OSD visible on both also)
    Xbox-360: visible only on projector ????????? (Amp OSD visible on LCD TV)
    I have checked that video conversion is switched on for all sources.
    I have tried changing xbox-360 to different resolutions.
    Any ideas?
    I will try swapping the inputs around tonight to see if it is a faulty input.
  2. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    What resolutions is the Xbox capable of outputting? I'm pretty sure the 4306 will only downconvert Component 480i or 576i signals to Composite.
  3. BruceH
    BruceH
    Dec 29, 2004
    260
    Weston-super-Mare
    +9
    The xbox will output 480, 720p or 1080i.
    I'm fairly sure that even 480 was not being downconverted, but I will check.
  4. BruceH
    BruceH
    Dec 29, 2004
    260
    Weston-super-Mare
    +9
    just checked, the xbox only output 480p, 720p or 1080i on component.
    The 4306 only down converts 480i or 576i.
    Will have to see if I can connect a composite from the xbox as well as component?
