AVR-3802 & FS2-AV Crossover Settings
Discussion in 'AV Receivers & Amplifiers' started by billduff, Mar 18, 2002.
  1. billduff
    billduff
    Mar 17, 2002
    275
    16
    Just to the right of civilisation
    I have just got a AVR-3802 and Missions FS2-AV. Got them setup and sounds fairly good.
    I am new to all this and am trying to 'tweak' the setting. One thing that is obvisious is that the Amp allows a crossover setting og 80, 100 or 120 hz whereas the Missions use something like 235.
    how can I set the crossover higher on the amp or is there a way to get the amp to ignore it and let the Mission's sub-woofer do the work.
    Bill
  2. andyk
    andyk
    Dec 31, 2001
    769
    46
    North Yorkshire
    +166
    you should set your speakers to large (you don't get to choose a crossover frequency then)
    All of the signal goes to the sub, which will split it between itself and the satellites using its 235 Hz crossover frequency.
  3. billduff
    billduff
    Mar 17, 2002
    275
    16
    Thanks Andy.
    I had already set the speakers to large but had set the crossover before I did it. You are right though and I cant see the menu option anymore.
    Bill
