AVR 300 v FMJ A32
Discussion in 'AV Receivers & Amplifiers' started by davrid, Jul 17, 2005.
Tags:
  1. davrid
    davrid
    My sytem requirements are pretty straightforward - the only conections will be DVD (also to play CD), receiver and Plasma TV, and possibly my playstation and skyplus.
    Assuming I purchase an Arcam DVD (either DV 79 or DV 29) what would be the best amp/receiver solution an AVR 300 or the FMJ A32 fitted with mutlichannel board? I have no need for the tuner and given the few sources connected, unlikely to need upscaling etc - at the moment Sky is just connected using a scart, making do with 2 channel audio, which for me is really ok - as use more for the recording facility.
  2. ruben20
    ruben20
    Jan 28, 2004
    76
    Netherlands
    +3
    The 300 comparing with an A32 is like david and goliath. It's a little blown up but the A32 is miles ahead of the avr 300. If you compare the prices for instance, the avr is somwhat more expensive, but if you see that in the context of the amount of amplified channels and other technical aspects that are used(video switching and stuff), it should be simple to add up. The a32 is another league in comparison. Mind you that costwise the option of the a32 will hurt your budget quite severly. The 7.1 board, the added 3 ch amp, which should be one of a FMJ type(p35 3 ch.) etc.
  3. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there, i compared an AVR300 to my A32 in stereo last year and didn't find a huge amount of difference between them -it defiently wasn't night and day. They were driving Quad 22L's.
    CaM
  4. Dillon
    Dillon
    Apr 27, 2005
    57
    Nottingham
    When I went to my dealer to get a new amplifier, I went with the intention of getting an AVR300. The dealer suggested having a listen to the A32 too, and I thought the difference between them was like chalk and cheese. Needless to say I got the A32, and have been very, very happy with it. (although I did hear a Sugden A21SE the other weekend and thought it was superb)
  5. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    I too have had a soft spot for the 32.
