AVR 300- pop sound when changing inputs, is this normal?
Discussion in 'Arcam Owners' Forum' started by Duster, Jan 18, 2005.
  1. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Can you tell me, is this normal for the AVR 300- when changing inputs,you can hear a low click/ pop from the speakers, is this normal?
    And when playing back DVD's, if the sound changes from one sound format to another-IE from say- Dolby Digital to Pro logic IIx, or any other sound format. you get the same click/pop sound from the speakers is this normal?
    Thanks for any help. :smashin:
  2. blitzschnell
    blitzschnell
    It all depend on your definition of normal ... My 250 does the same and some switching (espcecially pcm to dolby ) produce frightening sound !!! It has nothing to do with "smooth" clicking when changing input, it is way much louder, at some occasion my cat had to investigate behind the speaker to be sure that no mouse was around. I hope thay can address the problem anytime soon !
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Thanks for reply,
    Wow that doesnt sound good, If that was my AVR, I'd take it back.
    The sound I get when switching sound modes is just a low pop/click sound.
    Strange that my old AVR (Yamaha) was only £400 and that never made a sound when changing sound modes or inputs, and the AVR 300 is £1300, and it does make these unwanted sounds.
  4. davehk
    davehk
    Oct 17, 2003
    701
    28
    London
    +45
  5. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Thanks for reply,
    Nice, i'm running 3.0.1 at the moment, i'll have to try and get 3.0.6 then. :)
  6. CHX
    CHX
    Hi Duster,
    does Firmware 3.06 solve your problem?
  7. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Sorry, Ive not had the time to install the update yet, i'll post back when ive done it.
    Do you get this problem then?
  8. CHX
    CHX
    From ARCAM support I have receive the following Email:
    Yes there is a slight noise when changing inputs and also mode/surround
    selection as well, this is normal.
    So, the SW does not solve the problem. I have installed SW 3.06 (Before I had 2.84).
    It is a great pity, because the sound of the AVR300 is really excellent.
    Perhaps the Arcam engineers should talk with Yamaha guys, how to design a noiseless input or surround mode selection. ;-)
  9. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Yes, I agree, It's one of the things I really hate about the AVR 300.
    I think it must be to do with the software that runs on the AVR 300, and the Yamahas dont run this sort of software.
