AVR 300 ... oh oh
Discussion in 'AV Receivers & Amplifiers' started by vittoboy, Mar 17, 2006.
Tags:
  1. vittoboy
    vittoboy
    Hi Arcam owner !
    Yesterday I have pressed the power on in remote command, to wake-up my AVR300 from stand-by status. But.... the power led not turn in green,
    it's starting blinking in red color !
    I have turned off with power switch and after i turned on, and now it's all OK.
    What mins a red blinking ?
    Vittoboy
  2. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    It could mean more than one thing, though if it doesn't happen again it was probably a one off glitch. I have seen a fair few with AV receivers/processors. Remember they are driven by software which by nature is prone to the odd bug.
  3. Jack Dotson
    Jack Dotson
    Take a look at the thread for the AVP-700. Several folks reporting this problem and the unit shutting down. Other post also identifed this issue with the 300. Fortunately I've not had this problem with the 700 yest, but it's only two weeks old. However, I've read enough post that I'm convinced there is an issue with these units that Arcam needs to adress.
