avr 300 o.k. for kef thx 4ohm speakers?
Discussion in 'AV Receivers & Amplifiers' started by filmman, Sep 5, 2005.
Tags:
  1. filmman
    filmman
    Nov 10, 2001
    252
    2
    brighton
    +7
    hi folks
    as the title says would a av300 drive a 4ohm thx package without any problems?
    many thanks.
  2. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,871
    83
    +272
    Imsure it will as you can set the impedance of the 300 to 4 or 8 ohms via a switch on the back panel.
