AVR 300 Fixed -now I got a question?..
Discussion in 'AV Receivers & Amplifiers' started by m1964, Aug 28, 2006.
Tags:
  1. m1964
    m1964
    May 9, 2005
    45
    :thumbsup: Recently I got my AVR300 from the repair shop where Digital Decoder was fixed - BIG THANKS to Tim from Bristol Electronics (took only 2 weeks).
    The firmware was upgraded as well as part of the repair.
    After re-connecting AVR I immediately noted that now Dolby ProII Music and NEO 6 modes are available when using digital signal/input.
    Prior to the repair these modes were available only from analog signal, not digital.
    Also, I had to turn down volume/level on my sub -previous setting was too high/too much base.
    It seems that new firmware has different sound management, and I wondwer if someone could explain the difference between old and newer firmware.
    AVR was bought about 12 months ago.
    Thanks.
    P.S.
    It is just great to have AVR back-I had to listen to those flat speakers that came w/ TV for 2 weeks...
  2. jeffstra
    jeffstra
    Jan 30, 2006
    45
