Avr 300 and M&K Speakers
Discussion in 'AV Receivers & Amplifiers' started by john R1, Aug 23, 2004.
Tags:
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Is anyone using the avr300 with m&k speakers, if so how do they sound am using 3 x k17 2 x k4s 1 x k15 and vx100 sub am at present using denon 3802 cant say had any problems running them, but would like a receiver with a quoted output into 4 ohm speakers
  2. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    I'm sure I read a post from John Dawson stating that the AVR300 had a 4/8 ohm switch at the back and that units were shipped with the switch set to 4 ohms.
  3. Shaka
    Shaka
    Jul 26, 2004
    756
    Glasgow
    +39
    Yep, the AVR300 has a switch so you can select between 4 or 8 ohm setting. Select 4 when using with speakers with a 6 or lower impedance, 8 for anything higher.
