AVR-2807 - Video Out has died
Discussion in 'AV Receivers & Amplifiers' started by Dunc_NZ, Sep 17, 2007.
  1. Dunc_NZ
    Dunc_NZ
    I've got an AVR-2807 that's worked sweet for about 6 months, then the other day the on screen display and the video thru (from the skybox or DVD) to the telly has stopped working.
    There's a chance I've pressed something silly on the remote; has anyone else come across this issue and managed to get it working again?
    Thanks in advance,
    Dunc
  2. Bagger
    Bagger
    May 8, 2007
    2,225
    Leicester
    +227
    Make sure you've not put it into pure direct mode.
    this will turn off some video circuitry.
    other than that you may need to reset the microprocessor check you manual on how to do that
