AVR-2805 Opt Audio Input
Discussion in 'AV Receivers & Amplifiers' started by vernonator, Jun 10, 2005.
  1. vernonator
    vernonator
    Jun 10, 2005
    3
    Greetings all - I have a new AVR-2805 and am trying to setup my system. I have 4 compontents that use Optical Audio and am trying to get them working. Here is what I have done -
    Plugged all the cables in to their respective inputs
    Mapped all the OPT's to the correct Device
    Set all the components to output in Digital Audio
    None of the 4 work. I can hook an Analog cable to any of them and get sound that way but not thru the OPT's.
    Also when I try and run the Auto Setup I get no sound from the speakers and it errors out.
    I know all the speakers are working as I can go into the speaker setup Menu and generate test tones for them all.
    I have tried resetting the AVR-2805 with no success. Is there anything I am not doing?
    I have tried to contact Denon Support but had no response, and the vendor I purchased it from has gone out of business (I bought it 4 mos ago and it sat in its box while our new house was being built).
    Thanks for any help you can give!!!
    Cheers !! - The Vernoantor
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    Have you got the audio input set to analogue by any chance? You should have the choice of Auto, Analogue or Ext In. Make sure this is on auto or the amp may bypass the digital inputs.
  3. vernonator
    vernonator
    Jun 10, 2005
    3
    Mini,
    I have tried both Auto and Digital.....no luck with either
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Have you tried any of the Coaxial digital inputs?
  5. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    There must be something seriously wrong. I plugged everything into mine, ran auto setup then assigned the inputs and it all works fine. I'd say if the auto setup is erroring out on you that there's a more serious problem?
  6. vernonator
    vernonator
    Jun 10, 2005
    3
    I have not tried the coax inputs...I did finally get a reply from Denon Tech Support and he had me try re-initilizing the micro processor (which I had already done). Have not heard back since.
    Yeah I am thinking mine may have issues. The bad thing is the place I purchased it from has since gone out of business so if it needs repairs I will have to send it to a repair center.
    Thanks for the help!!!
    Cheers!!!
