Avr-250
Discussion in 'Arcam Owners' Forum' started by @TOMMY@, Aug 19, 2005.
  1. @TOMMY@
    @TOMMY@
    Aug 19, 2005
    11
    1. When bi-amping, does it matter if I use the main L/R channels to drive the high frequency and 6/7th channels to drive the low frequency? or can I do it the other way around (because all channels should have the same amplification right?)
    2. My speaker wire has 8 smaller wires. My dealer suggests it would be better if I use 2 to bi-wire the high frequency and 6 to the low frequency. What would be the difference if I just use 4 and 4 instead of 2 and 6.
    Thank you
  2. Hifi addict
    Hifi addict
    1. haven't heard any difference and the amps should be the same
    2. depends on the speakercable you have. Best is to try and listen yourself. In theory, bas needs more energy/wires so that's why he suggested 6-2, but again depending on the quality of your cable, you should try 4-4 as well
  3. @TOMMY@
    @TOMMY@
    Aug 19, 2005
    11
    OK thank you very much. I shall try that :thumbsup:
