AVR 250 Remote Codes
Discussion in 'Arcam Owners' Forum' started by OneDesi, Sep 4, 2005.
  1. OneDesi
    OneDesi
    Mar 10, 2005
    8,113
    Black Country
    +242
    I've just bought an AVR250 and am trying to get the CR-80 remote to control my Harman Kardon DV22, Loewe Articos and Panasonic Sky BOX (got it to do the Sony VCR).
    I've tried the search instructions to no avail does anybody have alternative codes I can try - thanks in advance
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Have you tried teching the remote the codes from the original remotes?
  3. Mr Perceptive
    Mr Perceptive
    Jun 8, 2005
    38
    Mid-Wales
    The CR-80 is limited to what it will handle straight out the box, as Crustyloafer says if its not in the handbook you'll have to teach it.
    I enquired from Arcam whether further codes were available (as I wanted to control a Denon DVD player), but I was told that the CR-80 was made for them by a third party supplier and its codeset was fixed.
    Not very good for a £60 control I thought.
    Mr Perceptive
  4. OneDesi
    OneDesi
    Mar 10, 2005
    8,113
    Black Country
    +242
    Crusty
    When you say teach do you mean using the repetitive process outlined in the CR80 book - if so yes (It keeps picking up the video when I try to program the DVD player) - doesn't look hopeful this! :confused:
