AVR 2105 Sub won't 'wake' and 'goes to sleep' at normal volumes.
Discussion in 'AV Receivers & Amplifiers' started by AMc, Aug 10, 2005.
  1. AMc
    AMc
    Nov 20, 2000
    5,526
    Near Norwich
    +2,089
    (Posted this in the subs forum but no one had anything to say - hoping another 2105 owner has an insight)
    I've changed amps from a Yamaha A5 to a Denon 2105 because there seemed to be problems with the sub output - i.e. there wasn't one most of the time. The sub wouldn't wake from standby by itself and would go to sleep after 15 minutes as if there were little/no signal going to it even at quite high volumes. As I'm using a sat/sub combination there should always be some signal.
    Running the sub from a line level tape out - it seemed to stay 'awake' so I figured the amp was bad and the sub was fine.
    (I knackered the A5 plugging it into the sub with the power on fried the 'mute transistors' according to Yamaha on email - resulting in a nasty thud and nothing more from the sub output. Time for a new amp.)
    Unfortunately I'm still having problems with the new Denon. I need to turn the Denon master volume up to around 0dB to get the sub to wake, then turn it down and a few minutes later it will go to sleep as though there were little or no bass input - even though it is making a noticeable output.
    I've tried increasing the sub output to +12 in the amp settings and lowering all the other levels to bring up the master level on the amp - still the same effect.
    The sub seems to work normally when using a 5.1 source.
    I'm beginning to think the sub has a problem with the auto standby function but unfortunately there is no permanent 'on' switch. I also took it apart and the electronics are sealed so there's no way to by pass the auto off function. I would replace it but I'm worried that it's actually the amp has a very low output level and I could end up shelling out for a new sub and wind up with the same problem.
    Anyone got any suggestions I could try to keep the sub awake by a change to the settings on the amp? Had a similar problem with a 2105?
    Thanks for looking - any help welcome! :lease:
  2. Jase
    Jase
    Mar 16, 2001
    9,319
    South Coast
    +829
    Sounds like it's the sub that's duff if it's happened with two different amps. Does it have just one single input on it or is there two? If it's got two, then connecting a Y-Splitter cable can help. To be honest, if it's turning itself off even when you're listening at volume then I'd say it's got a problem.
    To maximise bass output in all modes, set all speakers to small, all bass to the sub if you're not doing that already.
  3. briancbb
    briancbb
    I recently bought a 2805 and had a similar problem. This was recified in the menus by changing the fronts to be +LFE. My sub comes on every time now except with the tuner and I think that is due to the low frequencies not being there.
    HTH
    Brian
  4. AMc
    AMc
    Nov 20, 2000
    5,526
    Near Norwich
    +2,089
    Thanks for posting people. It sounds more and more like my sub is duff. I've been trying with mains and centre set to LARGE and "LFE+main" which (in theory) should output bass through the sub and the fronts.
    Obviously if I set the fronts to SMALL then they sound even worse when the sub isn't in play as the bass is just lost.
    I'm going to have a few more plays and if all else fails use it as an excuse to buy a new speaker set when pay day comes :(
